What’s about the performance about NVIDIA Quadro 2000 Graphics adapter?
Anyone knows about NVIDIA Quadro 2000 Graphics adapter performance?
I'm using a quite old version now I think I need to upgrade it with the new version.
Please tell me about NVIDIA Quadro 2000 Graphics adapter performance that with 1 GB – GDDR5 SDRAM.
If I upgrade it I'm facing any problem in the future?
Thank You
Answered By 0 points N/A #81169
Yes, you surely need to upgrade your 3d card & NVIDIA Quadro GPU 2000 is very good & it won’t create any further problem for you in the future. This card is very nice & it provides excellent performance in affordable price.
GPU Specs:
NVIDIA Quadro GPU
Quadro 2000
CUDA Cores
192
Form Factor
4.376” H x 7” L Single Slot
GPU Memory Specs:
Total Frame Buffer
1 GB GDDR5
Memory Interface
128-bit
Memory Bandwidth (GB/sec)
41.6 GB/s
Display Support:
Dual Link DVI-I
1
Display Port
2
# of Digital Outputs
3 ( 2 out of 3 active at a time )
# of Analog Outputs
1
Maximum Display Resolution Digital @ 60Hz
2560×1600
3D Vision/3D Vision Pro
yes
Feature Support:
Shader Model
5.0
OpenGL
4.0
Microsoft DirectX
11
SLI Multi-OS Technology
yes
NVIDIA CUDA Architecture
yes
Mosaic Technology¹
yes
NVIEW Display Management Software
yes
FSAA (maximum)
64x
Thermal and Power Specs:
Energy Star Enabling
Yes
Maximum Power Consumption
62 W
Relative Performance Score
23.85
