What would be the best solution of Cloud Storage for Small Business?
Hello all,
I have a small Business set up in my city. It has four offices situated in the different parts of the city. The Organization generates lots of data every day, and we want to store it in the Cloud. So, what would be the best solution of Cloud Storage for Small Business?
Answered By 0 points N/A #86535
You can choose any of the Cloud Storage Clients that are available online but, if you go with my choice, it would definitely be Zoolz. Zoolz is a known name because it provides businesses, access to Cloud Storage that has a decent capacity.
There are no restrictions on the upload and download speeds of the bandwidth or the size of the files. So, it is always available at your service. Zoolz provides a “Tribird” backup service to your Business. This brings three storage options to your business.
1) Storage for the files you need daily.
2) You can use Cold Storage for the records that you don’t use much.
3) Local storage on the server of your Organization.
You can deal with 1TB of data using Zoolz at $30 per month.
This will be the best Cloud Storage Option for your Business.
