No of visitors who read this post: 1268
Type: Question
No votes yet
What Is wlidcli.dll File – How to Fix wlidcli.dll Missing Error Properly. I searched for it from the internet but I could not find any result. Can you provide me the proper solution to resolve this issue? I would be grateful to you.
The program can’t start because wlidcli.dll is missing from your Computer
msnmsgr.exe – System Error
Computer. Try reinstalling the program to fix this problem.
        OK
Comment viewing options
# Comment Id: 149195
Hi Calvin,
As the error says
"msnmsgr.exe – System Error
Computer. Try reinstalling the program to fix this problem."
It means that you did not completely installed the software so as to be able to solve the follow the error as it says that you need to reinstall the software. If the same error or problem encounter I suggest to download your software in full package and make sure to install it without any error or problem encounter.
You can also go to your local drive C: > Program Files > Windows Live > Share then copy the "wldcore.dll" and "wldlog.dll" and paste it to C: > Program Files > Windows Live > Messenger, C: > Program Files > Windows Live > Contacts and C: > Program Files > Windows Live > Mail.
# Comment Id: 155398
Wlidcli.dll is a dynamic link library file that contains important functions of the concerned operating system. When a program is run it may go to wlidcli.dll for specific operations. If this file goes missing several programs of the system are affected.
The recommended solution to this problem is that you should clean the window registry. You can go for free registry scan or registry fix to get rid of these errors.
Or you download the dll file from a trusted website, install the file and register it on window systems.
You may also go for a thorough scan of your system as this may also be result of the security threats.
I hope this information answers your questions.
