Ryan Abate
30 points
Posted on - 06/23/2012
The old Oracle Database downloads do not seem to be available anymore online which makes this a problem for those who get a new computer and are wanting to use their old version of Oracle.
What versions of Oracle are still available for download?
Hi
 The problem of the failure of the student is also due to course overloading because here course is too much and time is very short and even student work hard. He doesn’t do well in the examination. The course should be enough so that student can do better in the exam,  you can handle this situation in any way.
How will you like to see the situation?
when there is nothing in the file? Then there is nothing that cannot solve in the problem and you can find it in a way you can find the solution.
