Jo Torres
Posted on - 09/13/2016
The usage of convert function is unknown by me. I need to know about that function and its usage. Is it related to date? I want to make the date to various formats. What is the use of convert function in SQL server?
B.makone
10 points
What Is The Use Of Convert Function In SQL Server?
The convert function in SQL Server is as you said is used to format the date in the output. When you enclose the date format you require and the original date it will automatically change the date from the inserted date to the specified format ant this function will return the formatted date. So this function is used to convert the date from one date to another and opposite.
