What is the tool for flash disk online format?
What is the tool for flash disk online format? I need to download the tool from online so that I will be able to format my flash disk or is there any faster way to do this directly in the website? I wish you could help me regarding this matter. I need a correct and accurate solution to resolve this issue.
Best Answer by Toni Linscomb
Answered By 60 points N/A #183512
Hi Christine Yong,
As you know, from Google you can find a lot of forums but the chances of getting the right solution depends on where you post your problems. We have so many different forums to get the tool for flash disk online format.
So classifying and posting them on relevant forums is the best way to get your answer step by step. I can suggest you some good forums, which are listed below:
1. https://www.sobolsoft.com/formatusbflash/download/setup.exe
2. http://soft.udm4.com/downloading/online_format_kingston_pen_drive/
Answered By 5 points N/A #183513
You don’t need any online tools or software to format your flash drive. Just follow the steps below and you’ll be done in seconds.
Plug your flash drive to any USB port on your computer.
  1. First please remove any necessary files from your flash drive because once you format the drive you’ll not be able to recover them back.
  2. Right click on the flash drive icon select Format.
  3. Select File system as NTFS.
  4. Click Start.
Process will complete within few seconds.
