What is the purpose and use of Windows startup watcher?
Hello experts,
What is the purpose and use of windows startup watcher? If you have some knowledge on this kind of application in windows operating systems share it with me. Also discuss some important details to consider regarding windows startup watcher. Thank you.
Answered By 0 points N/A #184640
Hello Thomas, A windows start-up watcher allows you to disable or remove files and registry entries of your computer. Viruses often run processes, modify the registry, and create files in Windows system directories you can use a windows start up watcher program to detect an infection in your system and disable the registries. This kind of programs can also be used to improve the startup time and the performance of your computer. However it is not recommended to alter the system files until you know well about what you are doing. I recommend Tiny Watcher for this purpose.
