What is the importance of gold price Plugin?
Hello techyv,
What is the importance of gold price plugin? How can it help you in wordpress if you have this kind of plug in application? How does it work and what are the advantages and disadvantages of having this plug in. I am very interested about it so please let me know.
Expecting some help from you guys. Thank you.
Best Answer by Alfaro Marthar
Answered By 0 points N/A #186567
Dear Benjamin,
Actually gold prize plugin output a simple plain text what is allowing you to edit easily the style and look with the wordpress WYSIWYG post and page editor.
Advantages:
  1. You do not have to hire a developer to place gold price on your WordPress website or blog.
  2. It updates automatically every 1 minute.
  3. There are no costs, backlinks or advertising.
Thank you.
Answered By 0 points N/A #186568
Hello Benjamin,
Plugin is a small set of software components that give specific ability to a larger application, e.g., web browser. Gold price plugin allows you to post the spot price of gold, silver, etc easily on your WordPress blog or website.using only very simple short code.
You can install and use this plugin by following the steps listed below using your WordPress dashboard.>Login to your blog>Go to Plugins>Select Add New>Search for Gold Price Live>Select Install>Select Install Now>Select Activate Plugin>Go to Tools>Select Gold Price Live>Choose Your Options and Update>Confirm and Enable>
Place [gold_feeder], [silver_feeder], [platinum_feeder] or [palladium_feeder] Short code on your Website in Pages, Posts, Widgets and your RSS Feed. You must include the square brackets as well.
Visit  https://wordpress.org/plugins/gold-price-live/#faq for more information.
Alfaro.
