No of visitors who read this post: 281
Category: Windows OS
Type: Question
No votes yet
I have always heard about firewall since I started using computer but till today I am not clear about what it really does.
If you can explain about the firewall in windows operating system, I would be delightful.Thanks.
Comment viewing options
# (Solution Accepted)
Hey Edward Morley!o come in your home.
To know about firewall, let us first elaborate the word "FIREWALL". It is a wall of fire which prevents other users to come in your home and keeps you safe in the home.
Basically network gateway server has some related programs which are called firewall. These programs prevent other users from the private network.
Firewall completely check whether to send the packet data or not, to the destination. When we install any antivirus, it also has a firewall. When we open a certain site which has some malicious virus, the Firewall suddenly block that site to open and prevent you from any loss of data.
I hope you understand it.
Thanks
Hi if you are using a personal computer in your home you must do the first step to prevent your pc is to turn on firewall. Firewall is a software program which aid to screen out the hackers or unauthorized access and remote access specially viruses and worm and also prevent unwanted files which download or upload over the internet. Overall function of the firewall is preventing your PC. That’s all. I think that I gave you the clear answer which you can understand. Thank you.
