No of visitors who read this post: 276
Category: Lotus Notes
Type: Question
Your rating: None Average: 5 (1 vote)
In making some business aplications, emails,feeds, and calendars. That provides an easy to use, the one that has the capability to get my work done quickly. That has almost everything. What is the best thing to use for this kind of project, is Lotus notes user friendly or easy to use? How can I use that one?
Comment viewing options
Hi..
According to your requirements I think the best solution s to use the Lotus Notes. You can successfully complete your requirements using Lotus Notes.
Lotus Notes application suite has following components
·         E-mail
·         Calendaring and scheduling
·         Address book
·         Database
·         Web server
·         Programming
Lotus Notes is the relational database system. It is collaboration platform that provides client applications, developer tools and many custom applications.
Yes it is very user friendly and also easy to use. It has lot of plug-ins, tools and applications to improve the User friendliness. It is easy to compatible with other soft ware.
If you use the Lotus note version after version 8, they have very attractive and User friendly front end.
For more details please refer
http://en.wikipedia.org/wiki/IBM_Lotus_Notes
