What is the easiest antivirus for mini laptop?
What I need is something that is light and does not eat up lot of resources. Also, something that is easy to use and configure. Nothing really fancy just the basic scan and clean functionalities. Please recommend the easiest antivirus for mini laptop. My unit is Dell Inspiron Mini 1012.
Best Answer by VillarosaRoberts
Answered By 0 points N/A #190832
Dell Inspiron Mini 2012 has downloaded and tested the best four antivirus engines which are mentioned below will be free from any form of badware (viruses, spyware etc).
1. Bitdefender Antivirus
Bitdefender  is the maker of the world's foremost antivirus software which has proven the best in the industry at detecting phishing attempts in extensive testing by independent analysis firm AV- Comparatives.
2. NOD 32 Antivirus
NOD 32 which is also called as ESET NOD32 Antivirus 5 is the most effective protection to combat today's huge volumes of Internet and email threats . It detects and eliminates both known and unknown viruses, Trojans, worms, adware, spyware, root kits, and other Internet threats . It provides comprehensive antivirus and anti spyware protection without affecting your computer's performance.
3. Avira Antivirus
 Avira Antivirus software regularly updates itself with the latest Virus Definition File (VDF).It offers award winning protection for home and for business computers and eliminates many forms of malware including worms, root kits, and costly dialers before they run and halts unknown code that looks suspicious, and click, run, and protect no awkward options.
4. Kaspersky Antivirus
Kaspersky Antivirus is solution that rigorously protects your files and your identity from cyber criminals and the latest malware attacks. It is the world's fastest antivirus updates at home and business.
You can choose any one of the above antivirus suitable for your computer.
Hope this information helps you better.
Answered By 0 points N/A #190834
There are lots of anti virus for mini laptop but the easiest anti virus are easy to use and comfortable. Some name of the easiest  anti-virus are given below:
  • Panda anti-virus
  • Auslogics anti-virus
  • Acronis anti-virus
  • Rising anti-virus
You can use one of them or you may try all of them to select the best one by yourself.
Answered By 60 points N/A #190833
Hi, Alexander Mitchell
You may use a portable antivirus if you want to have a light and easier function for your mini laptop. There are a lit of antivirus for mini laptop that is light and easy to use but with different features. Your concern has been tackled on different forums. You may check the link below, it may help you decide on what is the best antivirus for your mini laptop.
Hope that helps you.
Thanks and more powers.
