No of visitors who read this post: 177
Category: Windows 2008
Type: Question
Author: Chad Brown
No votes yet
Hi guys,
I am having some problems running my Windows Server 2008. It keeps on showing this error message:
I’m confused what causes the error. Can you tell me how to fix this error?
Error:
This domain is not hosted on windows Server 2008, Which is a requirement for this program to work.
The program will now exit.
Comment viewing options
Attempt supplying debug=1 to your urlblast.ini data file and so mail the log file. It will lumber elaborated data about what urlblast is adjudicating to do.
Whenever I had to approximate I'd suppose it's a permits matter because urlblast demands to carry as an executive account and the directory for the log files demands to be writable by everybody but at that place could be something else going on as easily. You are able to either manually make a test account "user1" with the password "2dialit", assign another account data in urlblast.ini or carry urlblast below an account that is permits to make exploiter accounts. If you make the account manually you are able to make it a client or fixed exploiter account therefore that the browser will be carrying with depressed rights when doing the examining.
