No of visitors who read this post: 190
Category: Hardware
Type: Question
Author: Miyaka_aini
No votes yet
My friend has a laptop that has been filled with worms. As someone who works online, I am used to repairing computer problems on my own. So I volunteered to fix my friend's problem. I have already installed the wormblaster software. However, everytime I run it, the system will always crash down while the software is running. What should I do about this?
Comment viewing options
Hi Miyaka,
You need a computer maintenance checklist to be able to solve your problem. To be able to start computer maintenance checklist, you need to set the system restore point. You need to remove junk files and other unwanted files. First thinkg to do is clean up your disk:
  • Right click my computer
  • On the drive that you wanna clean, click properties
  • Then select disk clean up
  • Some examples of unwanted files or junks that you want to delete compressed old files temporary files and offline webpages
Another thing that you need to do is delete your browsing history.
  • On the web browser you are using, click tools
  • select intenet option
  • Click browse history and then click delete
I hope it helps.
Zorian
