What to do with defraggler disk health error?
i encountered some problems when I ran the defraggler in my computer. It stated that one of the drive's health has error on it. can somebody help me on what to check on this? Any information on defraggler disk health error is welcome so that i can see what the real cause of the error. thanks guys!
Best Answer by Mehdy Blancha
Answered By 0 points N/A #140092
You should download the latest version of Defraggler and install it. If the problem shows again then try the Error Checking tools of Windows. Initiate the program and restart your PC. After restarting the computer windows will check your hard disk errors. Now, run Defraggler and see the health of your drive.
Answered By 0 points N/A #140093
First Check your hard disk health and I recommend PassMark BurnInTest software for it and check it. May be few bad sectors will be there and recover it by recovering tool by founded on in internet. Then you can defrag your hard hand, Try those easy steps.
Good luck.
