What is the difference between these sound cards?
What is the difference between these two sound cards:
DG5.1 with Audio Processor : C-Media CMI8786 High-Definition Sound Processor (Max. 96KHz/24bit)
DS 7.1 with Audio Processor : Asus AV66 High-Performance Sound Processor (Max.192 KHz/24 bit) ?
I think is not only between 5.1 and 7.1….. Which audio card you prefer?
Best Answer by godfrey.bek
Answered By 0 points N/A #101330
The 2 sound cards that have been mentioned here are poles apart when we consider quality, price and performance. The DG5.1 is comparatively the cheap card which has good quality output along with stable drivers. The CMI8786 with a sample rate of 96KHz/24bit for playback and 48KHz/24bit is extremely low as compared with the AV66. The DG5.1 is a good choice if you want to use the sound card for daily routine use but on the other hand if you want to use a sound card for audio production then the Asus AV66 is the best choice with high sample rate and quality sound processing. My choice as a musical lover would be DS 7.1 which comes in with an Audio Processor.
Answered By 20 points N/A #101331
I see… So I have now all the information. Now I know the difference thank you Godfrey. Thanks for providing such information. Keep it up!
