What is the connection between blog and database? Is there a way that we can set a website with blogs on a database system? I mean, in some instances the company needs to record all the important information in a specific website including the blogs, articles, and threads on the forum. What is the best database system that can handle many data as possible?
Thank you.
Nina Mahrens.
Database is where all the information of your site or blog is stored. Most websites, particularly those that are used for marketing, usually go for web database because they need to have updates and feeding information which can only be provided through web database synchronization.
If you want a secured database, something that you can tweak if you know a bit about programming, then I suggest you use WordPress as your blog platform. You can even create backup copies of files and database to avoid losing them when your site gets infiltrated.
To know more about WordPress and how it works, visit this website.
