No of visitors who read this post: 366
Category: Desktops
Type: Question
No votes yet
When I try to open a game like LcdDem, it would not load. The game would crash and I could not proceed. It already has  the package for 2000 runtime installed but it does not do any good. What can I do to fix this problem?
Error:
LcdDem
 ???? æ, è ̈ ??????
Comment viewing options
Hello Jayson.
You said your problem was all games failed on your PC but you only mentioned LCD Dem which is a Japanese game.  Therefore, I am assuming that the actual problem is that you are having problems installing and/or running Japanese games.
If that is the case, then the only way for you to run Japanese games is to enable Japanese support for Windows.
Here is a link for Windows 7 Language packs and how to add it via Windows Update:
http://windows.microsoft.com/en-US/windows7/products/features/language-packs
You may also need to run it in compatibility mode if the games were made for Windows XP and lower.
Here's how to use Windows Compatibility Wizard:
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Moreover, for LCD Dem, there is an English version so you should probably try that first.
Hope this helps!
