What is the best thing in vmware disk active partition?
Hello experts,
What is the best thing in VMware disk active partition? Is this done during the reformatting of computer and laptop or during the installation of the operating system? I hope you can give me the exact information that I need regarding this issue.
Thank you experts.
Best Answer by marsh watson
Answered By 0 points N/A #180220
The best thing is a disk active partition, because if you have a disk active partition, then you can remove unnecessary and harmful data. If you think you will need any of your important data, you should back it up before setting up the partition.
Answered By 0 points N/A #180221
Hello Anthony Wendy,
By using the VMware disk active partition utility, you can resize or extend your VMware virtual disks. This can neither be done during the hard drive formatting or partitioning nor during the installation of Operating System. This will be done after the installation of VMware Converter application. You must be aware of the fact that this utility will do nothing with the physical hard drive of the system it will only resize the capacity of virtual disks which VMware uses to run virtual machines/servers on your system.
