What is the best software for laptop mic booster download?
Hi
I have HP 1000 notebook PC series laptop in my home. I have to record some voice segments for my lectures. I tried to do that but the recorded volume is not enough. I need good software for laptop mic booster download?
Thanks
Answered By 0 points N/A #134622
There are no available mic booster applications on the market but your computer has a built-in mic booster option. Most users do not know that since by default it is turned off. To enable your mic booster, click the start icon on your desktop and click on Run. Type sndvol32.exe to open the sounds option and click on advanced options. You will see microphone boost there and just click the box next to it to enable it. If you’re using windows 7, right click on the sounds icon at the lower right portion of the desktop and click open volume mixer. You should see mic booster there. Just drag the icon upwards to maximize the mic booster.
