What is the best rental inventory tracker app?
I have a fastgrowing rental business.
Unfortunately, I now find it hard to keep up with my costumers' demands.
Because of the increase in the number of our costumers, I am really having a hard time tracking the due dates and the schedules of the next rentals.
I think my current concerns would be solved by having a certain rental tracker application that would be helpful to my business.
What do you think is the best rental inventory tracker app that would fit my needs?
Best Answer by Caldwell Llanos
Answered By 0 points N/A #187889
Hi Marilou, congratulations for a booming business!
Anyways, due to your increasing demand resulting to additional work loads, I would strongly suggest you get a web based rental tracker so that you will even increase your sales online.
Two sites I suggest you assess would be rentaltrax.com and dbworks.com.
Enjoy!
Answered By 0 points N/A #187891
For rental business, You can try the software which link given below.
Rental Tracker Pro (RTPro) is the leading rental inventory tracking software which allows tracking equipment using both a barcode scanner and non-bar coding approach.
Ideal for use in the Set Lighting, Audio Video, Costume, and Set Props departments.
RTPro is the premier Rental Inventory Management software which will meet all your needs.
No matter how big or small your inventory is, you can try this.
Here is the link:
Answered By 5 points N/A #187892
Hi Marilou,
If you are dealing with Inventory Assemblies and you have tons of these then yes it would be best to go for a rental tracking software.
If you however just want to keep track per item (less than a thousand) then you can go for an accounting software like QuickBooks.
This software would cover most of your business needs. You can import all your inventory Items right away if you have an excel file ready.
You can also Invoice your customer from it and what’s good about it is that every transaction made from the software links to your Inventory items so you will have a good visibility towards your accounts Receivables. This software can help you keep track of your payables as well.
Plus the reports are already pre-made like Profit and Loss, Balance Sheet, Cash Flow and a lot more.
Click this link to see more of what this software can do.
Hope this helps!
