What is the best free VPN provider?
I wanted to ask what is the best free VPN provider in your opinion. I'm currently using TOR to surf anonymously or free proxies but TOR is slow and I don't know how safe free proxies are.
I want something easy with good speeds. I am not sure if there is totally free VPN provider, but I think that there are some that give some kind of free trial. So, I would like your opinions if you use VPN providers.
Thank you.
Best Answer by lee hung
Answered By 75 points N/A #103518
Personally I love Hamachi, since it also works on Linux (at least 32-bit). This way, I can setup an SSH tunnel for a SOCKS proxy, and browse from work over an encrypted tunnel.
Hamachi is good and free for personal use. here
Answered By 0 points N/A #103519
Luckily for you there is a whole range of free VPN providers out there from which to chose from. A very reliable one seems to be Hotspot Shield, which is probably the most popular free VPN service in the world.
It uses both UK and US VPN based services so you won't have to worry about WiFi Snoopers or identity thefts. Also, Hotspot Shield provides unlimited bandwidth and is available on PC and Mac.
Hotspot Shield Window Console
Another top choice is OpenVPN, a robust and highly flexible tunneling application that offers great speeds and provides great security using OpenSSL encryption with many security and control features.
