What is the best download for itunes auto gain?
What is the best download for itunes auto gain? I have so many music downloads that needs to be converted into other formats. I just want to know if what are the features and formats that the itunes auto gain software can handle. I hope you can help me with this. Thanks
Answered By 0 points N/A #188534
Your question sounds confusing. Are you looking for a software that can convert your audio files stored in your iTunes?
If this is so, try the WavePad Audio Editing Software. This is a complete feature music editor that you can run on Windows and Mac. You can record and modify all types of music files and add effects to them. It supports wav, MP3, gsm, wma, ogg and a lot more. Download it from the link below:
Download WavePad Audio Editing Software
Another one is Hear for Mac. This software will give you better sound quality on your Mac PC. This will allow you to improve the sound quality and control the speakers.
As far as I know, there is no Automatic Gain Control software or app for Mac. So you just might try to consider on some audio editors stated here.
