What are the top 10 pc boosters?
And can we download that software or application for free over the internet?
Give me the proper way on how to download and install it in the computer.
I am using windows 7 32 bit operating system.
Thank you.
Best Answer by Johnstoon Leen
Answered By 0 points N/A #140182
There are several pc boosters available on the internet for free.
Coming to the top 10 softwares it depends on the users to rate the software.
I can suggest you two of the best pc booster softwares  .
1. Pcbooster
2. WinPatrol 2007
Click on the below link to download pcbooster software for free.
Thank you.
Answered By 0 points N/A #196887
Hi Gregory Swisher
Well I found top 10 PC boosters for you and they are all free.
Top 10 PC boosters listed below
Tweak UI: (Ultimate User interface tweaks for XP under a single interface)
Google Desktop 5: (indexes all of your data files, advanced search option)
Double Killer: (Locates duplicate files and kills one)
Free Commander: (Functions to manage data stock, use this facility on USB and floppy disk also)
Task-bar Shuffle2.2: (Group open documents together)
Defraggler: (Defragment you System, Use this facility on USB drive too)
WinDirStat: (windows directory statistics in multiple views)
WinPatrol 2007: (Put Scoty, WinPatrol Mascot keeps an eye on your system)
Absolute Uninstaller: (Replaces Default add/remove programs control panel)
Eraser: (made surety that hard drive is wiped clean)
I hope you’ll like these 10 PC boosters which you will definitely use in future.
Good Luck!
Johnstoon Leen
