What Are The Differences Between Adobe Acrobat Versus Adobe Reader?
Asked By 250 points N/A Posted on -
I was going through the web to find the best PDF file reader. As we all know that Adobe is very popular in PDF files. But in Adobe, I came across Adobe Acrobat and Adobe Reader. I wanted someone to compare Adobe Acrobat versus Adobe Reader for me and explain them.
Answered By 0 points N/A #120372
There are many differences between both of them. Primarily Adobe Acrobat is used by professionals who create PDF and edit them. Adobe Acrobat can be used to provide security, make modifications on files and encrypt the document. Some would also make validation certificates and supplement into them for validation. Whereas Adobe reader is used only to view and make notes without editing or making changes in the original document. Used by normal users who do not create PDF files.  
