No of visitors who read this post: 233
Type: Question
Author: Adelya
No votes yet
Hello there!
Can somebody help me and if possible send me an email.
My school has a CD of Adobe Creative Suit but it has only one license copy, what are the consequences I have to face if I intend to use the same serial number at home?
Please guide me...
Thanks a lot...
Comment viewing options
# (Solution Accepted)
Hi user
Let me say flatly that it is illegal. I don't know how cyber laws are enforced on your country but legal action could be taken against you by the author of Adobe Creative Suit. So beware.
If you register it using the same serial key, it will soon find out that you are using a fake serial key as soon as it connects to the internet. If you decide to block it from the internet then you won't be able to get updates and patches for it. You will not get customer support.
So please buy the software and help those who works hard to create these software.
It is true that you can use a key that was registered for another computer. But if you will use the network on that computer then it will suddenly get a message that your product is registered with a fake number. Although in some cases it may not happen because users usually install new windows and it also make the change in your computer. So it is on the software company that it gives you access you access or not. If the program is most important then you can buy a new key or set the programs options to no update in program or not to check for update if this option is available in program. Disable the update in program and it will work fine for your computer also. I hope this will help you to solve your problem.
Michal joran.
