Hi expert,
I like to use different kinds of small useful software. I use windows 8. I need some small but useful software compatible with windows 8. Please, tell me what the best soft are. Oh! I’m a graphics designer. So, you can suggest me some graphics soft. It would be better if all those would be free of cost.
What are the best small useful software for windows 8?
Hello Brandon,
I recommend for you to use small soft wares like photo shine mini4.0, Adobe Photoshop CS3, Photoscape 3.6.3 all for graphics which can be got freely on the link and you also need Anti virus probably AVG which can also be got from the same link.
You will also need Adobe Reader and Cute PDF writer 3.0 to help you work on PDF files and lastly you will need VLC player 2.0.5 to help you play videos and audio files
