What application can I use to edit write PDF files?
Hi!
I have been using Adobe reader to view my PDF files, but this application does not have any options to make any changes to the document yet some of them are open for editing. Is there a particular application that can edit write PDF files? Your assistance will be highly appreciated.
Best Answer by Miguel Patterson
Answered By 0 points N/A #158579
Hello Jermaine,
You can use another PDF reader named “Nitro PDF” to edit your PDF document. You can find it from the following URL:
 https://www.gonitro.com/
You can also use Adobe Acrobat Writer. But my personal preference is Nitro PDF. Because using this software you can easily edit any PDF document. Beside you can easily convert your document in doc, excel, etc format.
Answered By 0 points N/A #158580
Hi Morrison,
You can use an application called adobe acrobat professional to make any changes you want in your PDF such as editing any PDF file, merge different documents, edit scanned documents etc. You can get the download from the following link.
You can also use "WritePDF"  which is compatible to both mac and PC, you can use it to add notes fill in PDF forms, merge new documents etc.
