No of visitors who read this post: 290
Category: Anti-Virus
Type: Question
Author: Lark7t7
Your rating: None Average: 5 (1 vote)
Because some of Antivirus is I already used and experienced what or how they Protect Pc from Viruses, Can you give me some which is worth it.
Comment viewing options
# (Solution Accepted)
I think the best antivirus is quick Heal Total Security 13.00 for all user. It protects all virus and everything which come from net accessing. It does not reduce the speed of PC and helps easy working. This is the super antivirus.
I agree! Quick Heal Total Security is a Super Anti-Virus. It protects or shields your PC or LAPTOP from viruses, worms, Spyware, Trojans, and other uncontrollable threats. Brilliant answer to important and crucial questions Techyv.com. This site has now evolved itself to all users everyday living. Users who most doesn't have enough time to a huge research. They'll just stick here at techyv.com cause it's all here!
You can use Bitdefender Anti-Virus Plus 2013 as well for second choice (if necessary). The antivirus technology for Windows to obscurely stop internet threats.
JP
Hi dear,
You are right that there is a lot of antivirus software available, but not all of them are perfect. This antivirus software becomes unresponsive very quickly, because some antivirus programs provide shields only against viruses, some for spy ware, and some for both, but any computer encounters hundreds of types of risks, like data theft, spyware, viruses, malware, and more. I suggest you use Panda Antivirus 2013, Pro Version. This will protect against all risks. It will provide a perfect guard for your computer. You can download it from this link.
I am providing the link for both the antivirus and internet security.
http://www.pandasecurity.com/homeusers/downloads/
