No of visitors who read this post: 223
Type: Question
No votes yet
Dear Techyv.com Experts, I have been using Norton and McAfee as my antimalware app for my Windows 7 PC. My problem is that it still makes my computer not completely secured. Do I need to change my security software?
Comment viewing options
# (Solution Accepted)
Microsoft Security Essentials is best antimalware app for windows application. It is developed by Microsoft so it is very useful for Microsoft OS. For Win 7 Combo of Kaspersky, Advanced System Protector and MacAfee are good as well. Advanced System Protector blocks the spyware before it enters into the system.
Hi Bray,
First of all, actual protection of antimalware app doesn’t really vary across operating systems. And also, Windows 7 have already been improved in terms of integrating malware and virus protection. But third-party software is still important to ensure the best protection from any unwanted programs penetrating your system.
If you already have this kind of application it would already provide you the basic protection just ensure that your database for it is up-to-date by having a regular update of the software.
But if you still want to have an application most suited to the functions of Windows 7, I recommend these applications:
BitDefender, KasperskyLab, Webroot, ESET Nod32 and also Norton.
I hope this helps.
