Weird Mouse Clicking Noise on Laptop
I have an ASUS F6Ve-B1 laptop. The problem is, it is starting to produce a nonstop  noise similar to a mouse click. I need to turn off the volume of my laptop to avoid hearing the noise but I usually listen to music so I cannot just turn the volume off forever.
It was working well last night so I really don't know what happened for this problem to incur. I need help please. Thank you.
Best Answer by Guzman Manke
Answered By 5 points N/A #103356
Before doing anything try installing latest driver of your mouse from internet. Go to Control Panel> Mouse. Then go to Hardware tab then select properties. Go to Driver tab, then Update driver. After installing it restart your laptop.
If problem exists, it may be malware or a virus which causing this problem. Scan your whole laptop with an updated anti-virus. Or this problem may occur simply for a faulty mouse. Replacing your mouse pad may solve this issue.
Answered By 5 points N/A #103357
In some cases the internal mouse pad causes noise.
Because the mouse tracker maybe damage in too much force pushing it hard to try to clean the mouse pad small brush it may have small debris that causes noise.
Or check the setup of your laptop if there are options to reduce some noise to it.and the last thing it's better to have an external mouse on hand.
