gran wesner
20 points
Posted on - 08/07/2012
Just now, I start off Koha and everything looks very well, but the Web installer gives some error. When I try to select language, it gives the following error message:
Software error:
Undefined subroutine &main::setlanguagecookie called at
/usr/share/koha/intranet/cgi-bin/installer/install.pl line 25.
I am using Ubuntu 10.04 and Koha 3.04.06. I also followed the INSTALL.ubuntu.lucid instructions.
What is the problem? Please help.
Web installer gives some error while starting with Koha
Hey you try to scan for viruses and go to your software to solve this .because this is an installing matter you must carefuly install  anything you need. Some times there must be a problem with your web browser check it also. try itÂ
You can just try to take the technical support of this software manufacturer.
On the other hand you can update your software. Generally this type error is occurred for using not up to date version of the software.Â
Hope those could be helpful to solve your problem.
