louise bowl
30 points
Posted on - 05/03/2013
I want to try another free trial for a security software and was looking for a way in disabling trend micro security pro that is currently installed on my PC. How do I do that? And can I enable it again if I decide to not go with the free trial?
Ways in disabling trend micro security pro
Hi Louise Bowl,
I have read the problem that you’re encountering with your computer. Unfortunately the only way to disable your Trend Micro is to uninstall it.
This is recommendable if you’re installing other security software to avoid conflicts. Trend Micro has a software called Trend Micro Diagnostic Toolkit that will help you uninstall it from your device.
You can download it from this linkÂ
http://www.softpedia.com/get/Tweak/Uninstallers/Trend-Micro-Diagnostic-Toolkit.shtml
