Watermark in Microsoft excel 2010
Posted on - 10/27/2011
Select Insert -> WordArt (in Text Group).
2. Select a style from WordArt gallery.
3. Type " wordart"
4. Select Format (in Drawing Tools Ribbon) -> Text Fill (in WordArt Group) -> No Fill,and then select Text Outline (in WordArt Group)
-> Automatic.
5. Select Format (in Drawing Tools Ribbon) -> Bring to Back (in Arrange Group).
Hello Loise,
Assuming that you are using ms office 2007 or ms office 2010, you can add a watermark in your document by following the procedure below:
Hope this helps.
__
Regards
Lee Hung
