Hi experts
After entering my username with password for a protected PDF file, I found an error in Adobe Acrobat on Javascript global security. What can I do now?
Warning : JavaScript Window – Protected pdf – Error
This document requires global security policy to be disabled. Please go to Edit > Preferences > JavaScript and uncheck the Enable global object security policy “checkbox”
Message code: 008
Please help me to solve this.
Thanks in advance.
This one of the most common problems faced by acrobat / adobe reader.
The fun part is that the solution for your question is in your question itself.
See it says you to uncheck something .
Didn't get it ??
I will explain step by step.
1. open your adobe or acrobat reader.
2. Click on edit at the top and select preferences.
3. Select “JavaScript” in the left hand categories menu.
4. Un-click “Enable global object security policy” and press “OK”
And you are done.
And thus your problem is solved.
