Want to download Microsoft encryption pack
Hi expert, I am using windows 8 OS on my computer. But it doesn’t work properly most of the times.
There are no Internet explore a new version and other references. So I asked this about my friend.
He told me to download the Microsoft encryption pack.
So now I want to download Microsoft encryption pack.
So please give me some links to download it.
Thank you.
Best Answer by Sandra R Butters
Answered By 0 points N/A #140466
Hello friend,
The Internet Explorer High Encryption Pack is included in the latest versions  of internet explorer browser.
It gives you 128-bit encryption, the highest level of protection possible for all your Internet communications.
At first you download it following the sites. Then install it easily and browsing.
You can download the latest version of Internet Explorer from the site.
Best regards
Answered By 30 points N/A #140467
Almost all versions of Internet Explorer are capable of 128-bit encryption. You can easily upgrade your explorer version to 128 bit encryption; you just need to check a few things. At first go to the Help menu then select the option ‘About internet explorer’ to identify the version of your explorer.
A window will come out there you’ll find your version number, note it then close it. Now navigate the explorer high encryption package download page.
Select the package for your browser version, listed it on the right hand side of the page. A new window will appear now click Open, Next and Accept respectively. Now high encryption package will download on your computer and upgrade the process automatically. After complete the process select Finish. The high encryption package will be on your computer.
Hope this could be a help.
Thank you
Answered By 590495 points N/A #306797
If you just upgraded your computer to Microsoft Windows 8, make sure your computer meets the requirements. Most common problem associated with a not properly working machine is because the computer itself falls short on some of the required components. Before you install or upgrade to Microsoft Windows 8, check your hardware specifications.
Microsoft Windows 8 requires at least 1 GHz or faster processor with PAE, NX, and SSE2 support, 1 GB RAM for 32-bit and 2 GB RAM for 64-bit, 16 GB free space for 32-bit and 20 GB for 64-bit, and Microsoft DirectX 9-compatible video card with WDDM driver. Now, if you already have Windows 8, you should upgrade to Microsoft Windows 8.1 to have a continued support.
Windows 8.1 is the latest Service Pack for Windows 8.
