No of visitors who read this post: 1222
Category: VMware
Type: Question
No votes yet
Hello, I am trying to connect VNC via a live connection. I see an error message while looking at the remote machine directly. The error message is shown below. Thanks in advance.
Error:
VNC Server status and Troubleshooting This page shows the current status of VNC Server and helps to diagnose common configaration problems.
Comment viewing options
Hello Martin.
The mirror driver is a virtual graphics card driver.  Its purpose is to help your VNC viewer to update its display quicker while using less CPU time.  With a mirror driver installed, the VNC server can send details on changes in the display faster to the VNC viewer.  What this means to you as a user is your remote session will almost seem like being in front of the remote machine.
Your problem is most likely caused by an improper installation.  You should reinstall RealVNC yo have the mirror driver installed properly.
Below is the link to a RealVNC's own website with detailed instructions on how to install RealVNC including the mirror driver:
http://www.realvnc.com/products/vnc/documentation/4.4/#install
Hope this helps!
