Visual C++ Runtime must be installed before running Dragon Naturally Speaking installation
Hi world. Here’s the thing, during an installation of Dragon Naturally Speaking, I got this window message:
Visual C++ Runtime not installed
Visual C++ Runtime must be installed before running Dragon Naturally Speaking installation.
Please run setup.exe from the installation source.
Can someone enlighten me? Is there a fix on this? Please help me.
Thank you!
Answered By 10 points N/A #176829
Hi Jesus,
Dragon Naturally Speaking software requires that Visual C++ must be installed before running its setup.
Here are some ways to fix the problem that you are facing –
  1. Initiate the installation from setup.exe found in the installation DVD, this would automatically install Visual C++ Runtime.
  2. In case if you are installing from msiexec.exe found in the installation DVD, then you must first manually install the Visual C++ Runtime by running vcruntime.exe
    1. Find the directory ISSetupPrerequisites/VCRuntime on the installation DVD. In this directory you will find the vcruntime.exe and vcruntime_x64.exe files.
    2. Copy the vcruntime executable files to a convenient location.These .exe files install Visual C++Runtime for Dragon.
I would suggest following approach 1.
In case if you have further queries, please do post.
Mclean Buono
