Viruses attack my computer and my valuable file is destroyed
Asked By 7060 points N/A Posted on -
Viruses attacked my computer and my valuable file is destroyed. Now I want to remove virus from my computer and recover my valuable file. Is it possible or not. If possible give me the method. I do not want to install windows XP.
Best Answer by Cheryl11
Answered By 0 points N/A #79523
Microsoft Security Essentials is a free download that protects the computer from viruses, spyware, and other malicious software.
It is recommended to uninstall other Antivirus software before installing Microsoft Security Essentials. It is available for download from this web.
Install and update Microsoft Security Essentials to help protect the computer.
Also, if you suspect that your computer is affected by virus or spyware, download and run the Safety Scanner from Microsoft that helps in removing viruses, spyware, and other malicious software.
You can also manually remove the virus by referring the error message and display in the vendor’s website and following the instructions provided to remove it.
Bye
Cheryl
Answered By 0 points N/A #79524
Yes, you can remove your virus by some powerful Antivirus system such AVG or Kaspersky and then recover your valuable and needed data from a powerful software which is EASUES data recovery software. This is the software which is the registered version you can download easily.
It is such a powerful and perfect data recovery software that it can recover all of your data from your old partitions of your hard drive as well. The following is the snap of this product.
