No of visitors who read this post: 228
Category: Virtualization
Type: Question
Author: Shady
No votes yet
How can I setup virtual machine software in my pc and know that there are many users working on that pc and every one with different operating system (windows seven, windows XP and UNIX) also mention advantage and disadvantage of that software?
Comment viewing options
Hi Shady,
Virtual machine is an operating system or an environment. The advantage of this virtual machine is that it gives the user permissions for his/her supervision.
The user doesn’t need to buy two computers. Other advantage of using virtual machine is it amplifies the hardware consumption.
You can freely use the PHP and SQL. It can freely be use anywhere in the Internet. And it is secure to use. But like other things, virtual machine has its own disadvantages too.
One of its disadvantages is it slow and not constant. You are not allowed to install application with your choice. And you can’t entree the virtual machine if ever the window put down the lid.
Truthfully,
Zaari
