Hello friends,
I received a forwarded email that states to view in HTML. But the problem is the bar; usually at the top that we can click and select view in HTML; is not there. In that situation how can I view this email in HTML?
Thank you very much for your co-operation.
If you want to view messages in html format in outlook 2007 then you need to click on Tools button and then go to the TrustCenter option, and then the Trust Center will open. Now Select the Email Security option in the left navigation and then check the box marked "Read all standard mail in plain text". E -mails can also be digitally signed to make digitally signed emails also appear in plain text check the second option as well. Finally a popup menu appears with the option to display as HTML. The E-mail Security option will take you to the Trust Center / Email Security option.
