I am in need of merging several PDF's into a single one, I don’t have Adobe Professional with me, Is there any VBA Utility to merge PDF files. If so, will I be able to get it free through internet or do I need to pay for that. Please do the needful for suggesting me on this point and guide me to find a good Utility to merge PDF's. Thanks
Greetings Jerome C Caringan,
Well for merging multiple PDF files into one you can try out PDFBinder.
It's a free of charge PDF merging software that you can download here. (click)
It's simple and easy to use.
Interface looks like this
Just run it, click ADD and select your PDF files. Used the UP & Down arrows to your content (in which order you want them to go).
Click Bind!
And you will get the document merged.
Hope this helps you,
