Variation between driver for fujitsu pen between Windows XP and Windows 7
What are the main variations of the driver for fujitsu pen that makes the peripheral not work on both Windows platforms of XP and 7, and is there a universal driver that could solve this issue?
Best Answer by Fenster Maxine
Answered By 0 points N/A #150524
I will suggest you to download DeskUpdate from here: http://support.ts.fujitsu.com/DeskUpdate/Index.asp .
Deskupdate is an application from FUJITSU for automatically software installation (Drivers & Utilities) and BIOS updates. Download the DeskUpdate application and install it to your computer. You may find this link very useful here: https://support.microsoft.com/en-in/help/18900/consumer-antivirus-software-providers-for-windows .
I hope you may have found answer to your query.
Answered By 5 points N/A #150525
Hi Jay Skarbos,
As I reviewed your issue, as you are looking for driver for fujitsu pen. Yes, there is some variations of the driver for fujitsu pen, because of operating systems. If you change the OS then you need to change the drivers also.
You can install driver for fujitsu pen, You can download driver for fujitsu pen from the below mentioned links:
https://www.fujitsu.com/us/products/devices/components/touch-panels/downloads/
https://www.fujitsu.com/us/support/
Enjoy fujitsu pen.
I wish this solution may be helpful. Thanks!
Best,
Fenster Maxine
