Vaio sd card drivers, I need help with this
Hi guys, I need help with my sony vaio drivers. A technician just reformatted my laptop. When the time came that I was going to use my sd slot. It wont work. Where can I find sony vaio sd card drivers? Can I download them? Can you give my a link to those site.
Best Answer by Schneider Matthew
Answered By 0 points N/A #150824
Hi Jeremy Slaterable,
If you are using Windows 7, there is no need to install a separate drive for SD Card Reader because Windows have the built in driver for this. If the default driver is uninstalled, then the device can't be accessed. There is an option to install this default driver. Follow the below steps.
Hit "Windows+R" to open the Windows Run utility and enter "devmgmt.msc" and press OK.
This will open the Device Manager window. In here, you can see the UserName and under this, the list of hardware devices available in your system.
Right click on the UserName and select "Scan for Hardware Changes". Now, windows will check for any missing hardware drivers and this will install the SD Card Driver.
If the above method doesn't work, please download the Driver Software for Sony Vaio series.
The installation instructions are also mentioned.
Hope it helps.
Answered By 10 points N/A #150825
Download the driver on your Desktop then right-click on the Application file and RUN AS ADMINISTRATOR.
Support for VGN-NR32S/S
Free download of sony vaio sd card reader drivers for windows 7
Wish this now works fine on your Vaio.
If you use windows 7 don’t need to download it. Win 7 contain pre built driver for this.
Hope to enjoy it.
Thanking you
Franke Mary
