Using DVD Fab and unable to run DVD Fab
I am using DVD Fab and I am unable to run DVD Fab without using the run as admin option on Windows 7 pro. When I attempt to run this software I get this weird error message. Now I am trying to fix it but I can’t fix it without an expert’s advice and suggestion. Please help me. Thanks in advance.
Windows cannot find ‘C:pprogra~2DVDFAB~3optionsDVDFabAddonBluRay.exe’. Make sure you typed the name correctly, and then try again
C:PROGRA~2DVDFAB~3OptionsDVDFabAddonBluRay.exe
Windows cannot find ‘C:PROGRA~2DVDFAB~3OptionsDVDFabAddonBluRay.exe’. Make sure you typed the name correctly, and then try again.
Answered By 5 points N/A #175758
Navigate to the physical location of the file in your local folder. Make sure it exist. The shortcut pointing to the location of the application may be causing the trouble.
Or your antivirus might be blocking the setup during the installation so it cannot write all files to the Program Files Directory. Try to temporarily disable it.
If it still does not work, install DVD Fab as administrator. To do this, right click the full installer, then click Install as Administrator.
