User friendly OptiTex 10 toolbars
Hello Techyv Guys, I am planning to have OptiTex 10 toolbars as I heard from friends that it is more user friendly now, can anyone suggest me the features and the improvements that are included in OptiTex version 10. If anyone is used with similar toolbars as that of OptiTex, please suggest me so that I can have an alternative plan in selecting the software.
Best Answer by Collins Toll
Answered By 0 points N/A #142160
OptiTex version 10 offers a significant advancement to a more helpful structure design/grading and 3D system, thus you will find it easier to run. It features:
  1. New File Structure to minimize memory usage and guarantee forward compatibility and XML connectivity.
  2. New license management architecture.
  3. A tremendously improved user interface.
  4. New utilities to rate up the generation process and connection between various departments.
  5. Added tools and features to speed up your actions and match pattern design needs.
  6. New converters to get rid of data transfer issues and increase the mobility of interacting with several CAD systems.
  7. A new and improved Online Help site, such as software documentation, expertise base and tutorials, is readily available at
For more specified feature, just follow these link
Answered By 0 points N/A #142161
OptiTex has a newer version which is the OptiTex version 11. They added some new features and improvements that will make it easier to use.
These are some of the new features:
1.    You can now review tab summary by just selecting it.
2.   You can see detailed contents of a link by just selecting it.
..and more.
The link below will help you through the installation process and setting it up.
