My Operating System is Windows XP with Code Warrior 5.0 and USBDM version 4A to my interface. Now I am getting an error when I am working with the Code warrior in which I already have some codes downloaded in. The error says that the target Vdd supply interrupted, please restore power to target. And it is asking me whether I will retry connecting or not. Should I retry then? I want to know whether someone else is having the same problem with me and how it was resolved. Thanks.
Here is a screenshot of the error:
USBDM - Target Connection Failure
Target Vdd supply interrupted. |
You can create a Project with USBDM support
USBDM is now completely supported by the Codewarrior project vizard. The following shows the required initial steps of creating a USBDM project using the wizard.
This will create a new project with a debug configuration for USBDM. It may be desirable to change some of the default debug configuration settings to suit your BDM. The following section describes the USBDM settings available.
