USB Mouse could not be detected when inserted to USB port
Asked By 7060 points N/A Posted on -
I am use desktop computer but now i face some problem and that is USB Port problem. My mouse system is USB but when i joint my CPU then it got power but does not work.
So what can i do? and what is my solve?
Best Answer by Mark Benson
Answered By 0 points N/A #79808
That’s a good question; mostly we are facing this kind of problems. Since the Computer accessories are not that good these days we have to figure out a lot of things. Anyhow for your problem it might be a USB port malfunction, you better change the port and try. The USB port might be defective, in most case a defective USB port will not work if you use any device with it.
However, if the other port works properly then simply after connecting the device run add hardware application so that the computer can easily detect the new device attached to the computer.
Answered By 0 points N/A #79809
You have a problem with your USB ports. Did you try another USB mouse? If you not tried then try it first. If you try another mouse that not working then You have to reboot your windows. After Reset up your Windows you can solve this problem. Install Windows XP Service pack 3, Windows 7 Home Basic or Ultimate 32-bit or 64 bit. Installing windows your problem will solve.
If you still facing this problem You should change your Motherboard. There are many well known Brand of Motherboard such as: Intel, Asus, Gigabyte, Foxconn, MSI etc. But You can use Gigabyte or Foxconn. There are several Model of these brand that can match your configuration. You might also change your RAM. If you are using DDR-2. Place it with DDR-3. I hope you got the answer.
