Upgrading to Windows 8 Consumer Preview
10 points
Posted on - 04/12/2012
Well you cannot update to Windows 8 consumer preview using the Windows Update. Windows Update is just used for updating files of your current version of windows. To update to Windows 8 consumer preview you can either:
My personal advice to you would be not install the Windows 8 consumer preview for the reason that it is not a complete windows. Wait for the complete package to release, and what is released then install that 🙂
Hi zarah,
No, windows update will not redirect you to windows 8. update is used only for updating your windows version. Thanks.
