Upgrade office 2007 as office 2010 by fixing office add in
Hello expert, what can I do when if a security warning asks if I want to enable or disable office add in to office 2007? Also how can upgrade office 2007 as office 2010 by fixing office add in?
Answered By 0 points N/A #179133
Here are the instruction on how to upgrade from office 2007 to 2010:  If you purchased office 2007 and you have a product key you can easily upgrade but if you did not install it yet, then you should proceed  and install office 2007 first. Then activate your product, upgrade, enter some information about your Office 2007 and open Word or any other Office 2007 application.  Click the Office Orb, and select Options on the bottom to get the key. Select the Resources button on the left and then click About, Enter your Product ID and click ok.  Now, Proceed to the signup page in your browser  and enter this Product ID then, wait few minutes the system will check the key.  If it is validated, an order page  will show the edition of Office 2010 and you will be able to receive the upgrade download for free.  Look at these images, they will guide you through the process.
I hope this is helpful.
