Updates for your McAfee products were installed.
Hi Experts,
I received an error message while installing 3D Mark 11 on my machine. It is regarding McAfee security software. Have a look at the error message below. What does it mean? I have no clear concept for the error message. If you have any idea for the issue, please help.
Thanks in advance.
Restart Required
Updates for your McAfee products were installed. Restart your PC to complete the update.
Best Answer by Trotsky Timothy
Answered By 0 points N/A #192119
Hi Olivia Aust,
It’s a non issue! Just press ok and let your computer restart.  It’s a normal process when upgrading some software like antivirus programs, because some components of the said software is still running in the background and upgrade files will take effect only after the machine is restarted.
Answered By 10 points N/A #192120
It is not actually a very big problem. If you want to install 3DMark 11 in your machine then you need to restart your computer and then the program will start perfectly. It is just a simple problem for your machine. You also need to update the program if that needed. Then you can work properly. So thank you for your question and i think you get the answer.
